Forscan Updates to my 2021 Max XLT
wercsje1
Salem, OR
This is all the mods I was able to do to my 2021 Expedition Max XLT using Forscan
Ignore the x’s
Global Windows- (OPEN) BCM 726-11-01 change to xxxx-xxxx-x1xx, 726-11-02 change to x0xx-***-xxxx, 726-22-01 change to 0101-0101-01xx, 726-27-02 change to xxxx-x1xx-xx, DDM 740-05-01 change to Dxxx-xxxx-xx, IPC 720-02-01 change to 7xxx-xxxx-xx (CLOSE) BCM 726-11-02 change to xxxx-xxx1-xxxx, 726-22-02 change to 0101-0101-01xx, 726-27-02 change to xxxx-xxx1-xxxx, PDM 741-05-01 change to Dxxx-xxxx-xxxx
Mirror Tilt (DDM 740-03-01 was BC8087 changed to BF) (DDM 740-13-01 added Fxxx to 1st set of numbers (PDM 741-03-01 added Fxxx to 1st set of numbers) (BD 741-13-01 added Fxxx to 1st set of numbers)
Temp above gauges IPC 720-07-01 changed middle EA to E5 reads 84190E5017B
Turn Signal Bump SCCM 724-01-01 xxxx-x*xx-xx change * to 0=1 flash, 4=2, 6=3, 8=5, or E=7 flashes
Heated/Cooled/Steering Wheel icon on SYNC screen- APIM 7D0-000-000 change to xxxx-xxxx-x6xx
Disable doo-doo-doo at start-up IPC 720-01-02 change to xxxx-x2xx
Steering wheel heat was HSWM 714-02-01 (0250505010)= 80F changed to 025A5A5A10= 90F or 5C5C5C= 92 or 015E5E5E10= 94 or 0264646410= 100F
Bambi Mode- BCM 726-39-02 change to xxx0-xxxx-xx
Rednecked
Arizona
Thanks for this! Can auto start off and on be disabled with forscan?
apex96
PA
Not without disabling the Battery monitoring system in forscan, from what I understand. This may result in a permanent warning light being displayed on the dash. Best bet is to look into the auto start-stop eliminator and not attempting it through forscan.
Rednecked
Arizona
I tried to disable it with forscan. The program wouldn’t even let me. I purchased the auto eliminator instead.
mseymour67
Columbus, OH
Ignore the x’s
This will greatly help me with my 2021 Expy............thank you. Tried the easy mode but couldn't find these and have been trying to find a spreadsheet for the as built method. Thanks again.
Mr Big
Tampa Bay, Florida USA
I used this method for Bambi Mode. There's also a lot of other modes that can be done this way as well. It is so much easier and less apt to make a huge mistake. Also, remember to always backup before making changes.:
Once in Forscan, go to Configuration and programming, BdyCM Configuration
Up on the filter search, type high
Click on Fog lights if high beam is on
Enable it and check
Click write
