aeorn
Hey guys,
Diagnosis question for a 2000 EB 4x4 Air Suspension, 240K miles, Second Owner.
The truck runs out of gas when the gauge reads 1/4 (dies in the road dead). It's not a big problem, I just hit up the gas station accordingly. It usually takes around 18-19 gallons with topping off. I finally looked into it because the range is disappointing and found out she should have a 30 gallon capacity.
I'm thinking the gauge and capacity problem are related. Maybe an issue with sender/pump/pressure regulator? A brick in the tank? I'm not sure how to diagnose other than pull out the fuel tank and poke around.
Any clues or help diagnosing would be huge! Maybe someone has had this problem before?
Thanks!
Thanks!
