Let's See Those Lifted / Big Tire Gen 4s!!
Azureo81
Ontario, Canada
Finally swapped the factory 22s (285/45r22) for 18s from KMC with 35mm offset. I've always had good luck with Nitto Ridge Grapplers, so that's what I wrapped them in.
New tires are 275/70r18 (33") and fit great with no rubbing.
Chrome delete is up next for the weekend project.
I looks cool. I have the same tires on but in size 33x12.5x22. One of them just got ripped apart and I’m shopping for something else since this set is 5 years old and it does not make sense to buy just one tireIMG_0141.jpeg :( how did the chrome deleting come out? Just bought the vinyl and planning on doing it.
pequigah
Harrisonburg, VA
Yes, the F150 wheels will not fit the back axle. Need to trim it back about a quarter inch to get the dust caps on. I did mine with a sawzall.
Since you like the Tremor wheels with no lift...
@GixxerJasen Question on this ... Once trimmed can you go back to Expedition wheels if you so choose or is it F150 wheels from that point forward? Thanks in advance. Love how those look!
BP 09
2018 XLT 4x4. Basically a base model
Expedition Bilstein 5100s set on the highest setting front and back for a 1.5 inch lift. LT275/70r18 BFG KO2 on factory wheels. LT was a must for me with towing and rough roads in my area are hard on tires. Also removed the front air dam when I upgraded the intercooler and love that look too. Just different enough to notice but rides and drives great.
GixxerJasen
DFW TX
It's just extra threads. You don't thread or unthread anything to it to change the wheels, so yes, you should be able to.
pequigah
Harrisonburg, VA
Swapped out the Stealth 22's for a set of F150 Tremor takeoffs. Good, bad, right or wrong, I used a 1/2" spacers (which isn't noticeable) on the rear axle rather than cutting the spindle threads to get the center caps to fit. Ride is significantly improved and it no longer has that bouncy feel on the highway.
AFTER:
GixxerJasen
DFW TX
Welcome to the Expedition Tremor Wheel Club, I think there's only like three of us. They do look really good on our vehicles.
Jefes_Shyt
