Multi-Malfunction: wrench light, refuel warning, tire pressure fault, speedometer quit.
jgb113
Oregon
Hi everyone! New member here with a very similar experience another member posted about in 2021.
Owned my 2014 expedition for about a year never had any issues with it. Two weeks ago I had similar experience, Multi-Malfunction: wrench light, refuel warning, tire pressure fault, speedometer quit. I was about home and turned off the vehicle. Re started it after a few minutes and everything was back to normal. 3 days later it happened again. Exactly the same thing. 3 days later, again! Anyone have any suggestions?
99WhiteC5Coupe
Scan the vehicle for any fault codes.
Inspect the battery terminal connectors and posts - clean as needed. Note if you remove one or more of the cables, you may erase any stored fault codes.
Check the condition of the battery.
