NGK Ruthenium Plugs?
Left Coast Geek
Mid Left Coast
If plugs last too long and aren't periodically removed, they can end up welded to the block and become very hard to remove. I remember this was something of a problem on the early 5.4L Triton motor where the stock plugs had a 100K life.
gtr09
Midwest
They are the best you can buy for the Ecoboost, most people running tunes are using those. Usually gapped at .028 (not sure that's necessary at stock power) Put some nickel anti seize on when installing and they're less likely to stick over the long haul.
D
Dice Roll
Craps Table
Thanks I was wondering if they did well, sounds like they do.
I wouldn’t leave the factory ones in for 100k and wouldn’t these either. I think it’d be about thirty bucks more than iridium.
