I have a 1999 EB 5.4 Expedition with a no crank, no start situation.
Last Wednesday night after work, it wouldn't start, started perfectly fine when I left for work, no signs of trouble, just didn't start all of a sudden. Tried jumping it, but no dice. Battery was 11.9 volts, and was 5 years old, so I bought a new battery since winter is coming, everything has power but it doesn't crank.
This is what I have tried so far and nothing has worked:
* Replaced battery, it was 5 years old.
* Tried moving the shifter to Neutral as part of investigating whether the shift bushings were worn out.
* Checked under the dash to see if the shift bracket is loose, and it is not. Both this and the one above are from youtube videos from FordTechMakuloco.
* Battery cables appear to be good, but I have not cut the insulation to find out if there is corrosion.
* Checked the connections to the starter, and they appear to be solid without much corrosion.
I have not checked:
* Fuses, although the truck was running perfectly when I shut it off and went into work, so I doubt it's that.
* Starter solenoid.
* Ignition switch under the dash.
* Neutral Safety Switch.
* PCM relay.
I'm looking for advice on what to do next or if there is something I am missing. I'm fairly experienced with Saturn S-Series, but the Expy is different and I'm getting to know it better, but this no crank no start is confounding me.
There is a video on youtube about how to start an F150 by shorting two contacts with a screwdriver, has anyone tried this? I don't know what those two contacts go to.
I could tow it to a shop but my favorite shop is booked two weeks out and might have to find another shop that could take it in sooner.
I have not checked:
* Starter solenoid.
* PCM relay.
IF YOUR 1997-2003 F150 WON’T START, TRY THIS!
If your f150 won’t start you can try jumping the starter solenoid it’s on the firewall near the battery. If you’re stuck in a pinch this will get you home if...
www.youtube.com
