My rear brakes are not engaging far enough. With the rear wheels off SCR sitting on jack stands, the rear calipers engage just enough to stop the wheels at idle. Under a load they aren’t working at all. I drive 20 miles today in traffic and when I got home I was able to touch both rear calipers and there was not much heat in them at all so the calipers aren’t engaging with any pressure. The pads probably have 50-75% left on them. The brake pedal feels fine and doesn’t go down any farther than normal. The pedal isn’t spongy at all. I have removed the pads and rotors as weak as calipers and everything is installed correctly. I greased the caliper pins and everything is free. Does anyone have any ideas as to where to start? I feel like it’s a pressure issue but not sure if it would be master cylinder or ABS unit. There are no leaks and the master cylinder has plenty of fluid. Any ideas would be appreciated.
