Reman Engine Resources
blacktail
Floribama
I'm starting this thread for all of us confronting the dilemma - timing job, engine replacement or get rid of the truck.
I’ve seen lots of comments regarding reman suppliers (and opinions about them) but not a consolidated thread. I hope this information helps anyone else facing this predicament.
This is not an uncommon dilemma with the 5.4 3V:
https://www.youtube.com/watch?v=MARIUcyEnSk
https://www.youtube.com/watch?v=xcN_WcGr4BU
I know this subject has been addressed in older threads such as this these:
https://www.expeditionforum.com/thr...-replacements-sources-2012-2wd-limited.52369/
https://www.expeditionforum.com/threads/reman-crate-motor-vs-timing-job.50514/
https://www.expeditionforum.com/threads/engine-seized.50354/
My situation:
My 2006 Eddie Bauer Expedition has just past 182,000 miles. The truck is used as a daily driver and regular tow vehicle for travel and utility trailers. I have put 40,000 miles on it. It spent 8 months towing a trailer 13,000 miles two years ago. The interior and body are immaculate. The transmission was replaced at 135,000. I have replaced the suspension, (shocks, upper control arms, ball joints) and tires within the last 5,000 miles.
I recently relocated, using the truck as a tow vehicle on a few separate trips. Immediately afterwards I began to notice what I thought was an exhaust leak that is only audible when gassing the engine under load. Maybe a misfire due to old spark plugs(?). Listening more closely and trying to isolate the sound, I think I am also hearing the tell tale ticking of rocker roller bearings going bad on the passenger side. Started it this morning and heard what sounded like a rattle from the engine for a second, then normal idle.
So it would seem that in addition to my potential ignition issue, I likely also have a timing issue to address.
In my current location, I do not have a driveway or garage, but a sandy/dusty/windy parking area. Not somewhere I want to crack things open to do a timing job. So, I am confronted with a decision - pay someone to do a timing job/tune up, replace the engine or ditch the vehicle for something new.
Prefer to keep it, as my family loves it and most of the things that will go wrong, have gone wrong and been repaired - except the engine! To obtain a new (to me) vehicle providing the same level of comfort and towing ability would require a significantly greater cost than that of the repair.
So, tune up and time or replace?
I am leaning towards replacing it for the following reasons:
  • I don’t have a good mechanic I trust locally to do internal engine work.
  • Warranty on new engine.
  • New engine means all the other things that I anticipate failing in the near future will get replaced with install kit (pulleys, hoses, water pump, etc…)
  • reman engines mitigate underlying design flaws of this engine with machining improvements (supposedly)
  • Cost of paying shop for timing job and tune up seem to be ~60-75% of the cost of replacing the engine
So, where to source the reman engine?
Below I list a few options I have discovered during my research. The prices are approximate and may or may not include things like install kits, warranties or delivery. Some companies have different options in terms of upgrades you can choose from too. The prices and links are to the 5.4 3V that would fit in my 2006 expy.
Jasper - $6-$7000 depending on options. They claim numerous improvements over stock design to address common failure issues. The company advertises direct relationships with shops they list as preferred installers on their site. For someone without a good relationship with a mechanic (my situation now) could be a good solution. Their site is a little opaque. Much higher prices than other sources. Because they incorporate their preferred installers into their webpage, not sure if that includes installation? Highly doubt it.
Would be interested to hear from anyone who understands how the pricing structure with this preferred installer works. Are the shops paying Jasper a price closer to what the less expensive remans are charging, then pocketing the markup on top of labor costs?
https://www.jasperengines.com/products/gas-engines/featured-engines/ford-triton/
Direct from Ford - $5600 not sure if any improvements have been made to address the OEM design flaws.
https://parts.ford.com/shop/en/us/e...e-5gx694xaa-6gx692xaa-54l-p-5l3z6006brm?pdp=y
Fraser - $2700-$3500 depending on options/upgrades. Similar to Jasper, their higher priced option claims multiple improvements over stock design to address the common failure issues.
https://fraserengineco.com/5-4-liter-ford-triton-3-valve-engine/
Promar - $3200 No options, but claims multiple improvements over stock design to address the common failure issues. Looks like unlike the options from some other companies, timing chain cover, valve covers, oil pan, etc… are not included. Something to consider if you are weighing prices to have this done as the labor hours from removing, cleaning and replacing the ones from your old engine will add up.
https://www.promarengine.com/engine-details.php?pn=FO5.4-06
Powersource - $3800 No options beyond install kit, but claims multiple improvements over stock design to address the common failure issues.
https://www.ford54engines.com/product-page/ps5404w3tunp
Powertrain - $3900 They claim improvements in phaser and spark plug issues over stock design.
https://www.powertrainproducts.net/FORD-5-4-V8-ENGINE-04-06-F150-NAVIGATOR-EXPEDITION-p/1579.htm
If anyone has experience putting any of these into their expeditions - either by their own hand or paying someone else - please provide feedback regarding your experience.
If you would like to recommend any reman companies to the discussion, please do add them.
Finally, from everything I have read, there is not much hope of replacing the 5.4 3V with a DIFFERENT engine, due to the complexity. Obviously, anything can be done if you spend enough money. But, if there is a relatively straightforward option out there, would love to hear about it.
Thank you.
kep5niner
MO
Powersource (AER) provided my reman’d 5.4 2v long block last summer for my ‘03 EB. Great to work with. $3,150 on my door step, no core charge if core returned within 30 days - I was a little beyond that but they weren’t concerned. More details in my thread here. I did the work, have put 10k miles on the motor since, with no issues.
If you buy an engine through Ford, it comes from AER.
B
blacktail
Floribama
Thanks for your input kep5niner.
I noticed that Jasper offers an engine option that deletes the variable valve timing.
Anyone with experience related to this?
Here is their description:
VVT Delete​
  • JASPER offers VVT Delete as an option for the 5.4 engine.
  • The VVT Delete engine option will have pre-installed locks in the VVT actuators and also comes with a Livernois programmer.
  • The VVT Delete engine option is 50 state legal for 2004-2010 applications and includes a CARB E.O. sticker. 2011-2014 applications are CARB E.O. PENDING
B
blacktail
Floribama
In other threads, I have noticed comments about bad reviews for some of these manufacturers. Below are some of the reviews I found. Most of these also have google reviews, but I'm not sure how to include those links.
I imagine there is some selection bias going on in these samples. In general, people who are happy about a purchase aren't motivated to post a review, while those with a negative experience will usually want to vent.
Jasper
Fraser
Promar
Powertrain
Powersource
mbtech2003
capecod
Do an oil pressure test before you replace anything. If it’s within spec repair it. I did the phasers rockers lifters full timing kit https://www.freedomracing.com/5-4l-...gcxP6rh35yT1rM8aNpzFj4oYLYp8p6uRoCuuYQAvD_BwE
Don’t do aftermarket you won’t be happy. Jasper engines are hit or miss if they last. Never heard of the other ones. Otherwise I would get one from ford. My original 05 3v with now 196k miles is still running strong. Will outlast the body and frame. I did not pull my oil pan to clean out. I took the chance. Also did not do the oil pump. Up too you. Find a good guy to do it all right and you will be happy. That’s really the tough part.
Gary M
Portland OR
A year ago I had a Jasper reman installed in my '99 after it developed a coolant leak at the head gasket.199K miles. Since day one I've been back and forth with the original install shop, a Jasper recommended shop, about an engine rattle. ( another shop has since diagnosed the problem as piston slap). Jasper will send a new engine but the original shop is afraid they won't get paid by Jasper if the inspection on the returned unit doesn't show a problem, and with the poor diagnostics and delaying tactics used by the original shop for a full 9 months following the installation, why would I trust that shop now? I'm waiting for a 3rd opinion, as well as if I can get another shop to do the replacement.
Here's the deal- based on the number of engines Jasper produces, I think they basically make a good product. Occasionally any manufacturer will have a problem though. Jasper's model ( and similar) is to sell the independent, but 'authorized' installer the engine and rely on them to diagnose any problems that may arise, and proceed as they recommend. But if the installer is not good at diagnostics, or simply doesn't want to go through the R/R, (which on my rig I was told was 33 hours) and afraid they won't get paid by Jasper for the warranty labor, you wind up in the middle.
I don't know that you would have this issue at a Ford shop, but that is my guess. At the VERY least, screen your potential installer carefully. They are the one you will be working with directly in the event of a problem.
Best fortune on your project!
To hopefully help answer your cost question, my total cost, long block engine and install labor was $8,100.
