restraint warning
Mr Big
Tampa Bay, Florida USA
Shortly after lowering my 3rd row seats, a warning icon came up on my screen. My Ford pass reported this:
The restraints control module has detected a fault with the driver seatbelt retractor pretensioner circuit.
I'm not sure what this means as everything is working fine.
Can anyone shed some light on this?
99WhiteC5Coupe
The warning is self-explanatory. There is a fault code (defect) detected in the driver seatbelt system. The pretensioner (which is activated in a crash and tightens the seatbelt retractor) has a fault detected.
Take the vehicle to a Ford dealer to have the system scanned for any stored seatbelt code(s) and have it repaired.
HazBeen
Great Lakes
Hopefully by now, your dealer has corrected your Expedition's front seatbelt pretensioner issue, which may have involved this fault-detecting feature, described in the 2019 Expedition Workshop Manual...
Airbag and Seatbelt Pretensioner Supplemental Restraint System (SRS) - Overview
The Restraints Control Module (RCM) continually receives and monitors inputs from the Occupant Classification System Module (OCSM) , Battery Energy Control Module B (BECMB) and various other hard-wired switches and sensors. If the RCM detects a sudden vehicle deceleration and/or lateral deceleration based on the information received from the various sensors, and determines that deployment is necessary, the RCM applies voltage and current to deploy the appropriate SRS components.
The SRS utilizes Connector Position Assurance (CPA) tabs on deployable component connectors. The tabs disengage the shorting bars of the deployable component from its electrical pins and keep the harness connector securely attached to the deployable component.
If the connector is attached to the deployable component yet the tab is not fully seated, the pins of the connector still make contact with the deployable component pins. However, because the tab is not fully seated and the shorting bars are still applied to the deployable component pins, the RCM detects a fault (circuit resistance below threshold) during self-diagnostics when the vehicle is powered on (airbag warning indicator is illuminated).
Please be aware that Ford has issued an advance notice to dealers about impending Safety Recall 24S06, involving 2018-2020 Expedition/Navigator regarding inadvertent deployment of front row seatbelt pretensioners.
For more information, please see...
Safety Recall 24S06 - Certain 2018-2020 Expedition/Navigator - Inadvertent Retractor Pretensioner Deployment
Mr Big
Mr Big
It was immediately taken care of. Ford attempted to charge me, but I fought it and contacted a Ford Corporate Liaison, reported it and they waived.
The cause for mine was a pinched harness and airbag controller under the center console.
Mr Big
Mr Big
I posted another thread where the tensioner actually deployed in my car while driving. Picture a shotgun shell going off next to your ear. If I wasn't stopped at a traffic light when it happened, I would have wrecked the EX.
it was immediately taken care of. Ford attempted to charge me, but I fought it and contacted a Ford Corporate Liaison, reported it and they waived.
The cause for mine was a pinched harness and airbag controller under the center console causing a short and deploying the seatbelt tensioner charge. There are actually 12 in the vehicle, counting the airbags and seatbelts.
I'm glad they finally came out with the bulletin.
