Bolt snapper
It's almost impossible to accurately describe sounds (for me, anyway) in written form. I suppose I could make one of those videos where all you can hear is wind noise and everything but the sound in question.
I always run in 2WD (2004 Eddie Bauer). Often - especially when it's cold - when I take off after starting the car when it's sat for a while there's a fairly noticeable "wah wah wah" sound that is consistent with wheel revolution speed. You can almost "feel" a rubbing or kind of a dry rotation sound. I thought maybe the front U-joints, but they should be making sounds faster than wheel speed. I know everyone says failing wheel bearing sounds are different on these, but I've had several go out on different vehicles in the past and it's always a constant grinding - not a once-per-wheel-revolution sound.
I have noticed that the sound a lot of times occurs if I'm going over an uneven surface - like turning into a ramped driveway where maybe the right wheel is going up the ramp before the left one and the front suspension is slightly torqued. It will go away with speed or after driving for a while and warming up all the moving parts.
I'm hoping that, like most things, this is a somewhat common thing and someone else has experienced and can give me a starting point for places to look?
