Shocks N such
thereason21
Fremont Ohio
I have a 97 E.B. and i am noticeing that it seems to lean a little to the drivers side. So i naturally assume its about time for new shocks. I have been thinking about ranchos but i have seen alot of people like bilstien. Chances are my expy wont do much off roading so I was hoping for some replies and input before i buy some new shocks ...
thanx in advance ...
4x4Dude
Scottsdale AZ
I have been told that shocks actually don't adjust your ride hight, they only determin how stiff or soft your ride is. when you get a lift kit, the new springs and spacers are what makes your ride height change, not the shocks.
On my last truck which was a 98 gmc jimmy, it leaned to the drivers side and i found that there was a crack in my rear leaf spring. You might want to have those checked out as it might not be your shocks that are causing it to lean.
T
thereason21
Fremont Ohio
See i was wondering .... but wasnt sure ... question is how cheap is that? lol ... it doesnt matter ill probably do shocks n such anyway but i want to fix the problems first
4x4Dude
Scottsdale AZ
well it would benefit you to replace the shocks while you were replacing struts. Cheaper for the labor since they are already dealing with suspension.
As far as pricing goes for that repair...i remember on my jimmy it was really freakin expensive. it was around 2-400 for the actual part and labor was insane since it was such a huge job. I think i was quoted all together like 1200 bucks after all was said and done. after i heard that price, i just dealt with it leaning a little bit lol
Take it to a mechanic and pay him to do a once over diagnostic. He should be able to pinpoint why it's leaning and what can be done to fix it.
AvroAero
Toronto, Ontario
If your truck has air suspension check it. When you put it in park you should notice it kneel down approximately 2 inches. Maybe compare the front lowing to the rear. Otherwise just go underneath and look for leaky or blown lines. And check the front driver air bag.
Start the truck, put it in drive, and engage the emergency brake and use something to chuck the wheels for comfort. Then go under and use something that won't puncture it and check the front air bag and see if its pressurized. Compare it to the other 3 bags. It could have a leak and the passenger side bag is holding the truck up enough to keep the compressor from constantly trying to level the beast.
I would bet your air suspension is more likely the problem. I can't remember if air ride was standard on eddie bauers but I'm pretty sure it is. I work with a guy with a 97 EB with air ride and its been fairly problematic. But he overloads it often not to mention beats it. You may have a faulty sensor also that preventing the front from coming up, although I'm pretty sure there are only two. One for the back and one for the front so if one was messed either the front or back would stay high or low. So likely not those sensors.
I have not much experience with aftermarket shocks but ranchos seem to be pretty popular. If you are going to buy them buy stiff ones because these trucks have the shocks inside the chassis which can take a toll on body roll more than the average truck. If you really want a soft shock invest in a aftermarket roll bar also, front and rear.
FYI, if it does have air suspension you will have a switch on the passenger side by the kick panel. Right beside the passnger speaker. If you ever jack the truck up or have it towed MAKE SURE that switch is off. Otherwise you'll blow your compressor.
4x4Dude
Scottsdale AZ
Air suspension isnt standard on all EB. I have a 2000 EB and i do not have the air bags. I'm actually kind of thankful for this lol
Flangehead
Bremerton, Wa
Mine has air ride and doesn't do this. Is there a way to tell it to do that?
Sorry for digging up the old thread.
