Going_Going_Gone
About one time in ten trips, the driver's side power step hangs "up." For example: I can close the door and fasten my seatbelt, start it up, back out of garage, put in D and drive fifty or so feet around a curved section of our driveway before I hear and feel that step retract. Had it in to dealer on Wednesday for an oil change and the service writer had the tech clean and lube the mounting arm pivots, yet it did it again today. Regrettably, we've only put 9,200 miles on it, and most of them were in 2019. It's not been driven off paved roads other than a flat section of gravel access road a couple times per week and we drive very slowly there to keep the lift gate clean. Like the Auto Stop-Start that stopped working (a plus) and since I've conditioned myself to listen for the signs that the step does retract I'll tolerate both things to avoid leaving it at the dealership where they will probably be "unable to duplicate" the problem. Eventually there'll be a failure making for an easy diagnosis. Anyone else have this issue? Have it fixed, and if so, what was problem?
