SSM 51235 - 2018-2021 Expedition/Navigator - ELSD Rear Axle - Illuminated Powertrain Malfunction (Wrench) Indicator With DTC P0932:17
HazBeen
Great Lakes
Some 2018-2021 Expedition/Navigator vehicles equipped with electronic limited slip differential (ELSD) rear axle may exhibit an illuminated powertrain malfunction (wrench) indicator with diagnostic trouble code (DTC) P0932:17. Check the condition of the wiring harness and connections at the ELSD and the differential control module rear (DCMR). If no problems are found, clear the DTC and test drive. If the condition returns, refer to Workshop Manual (WSM), Section 205-02B.
Workshop Manual references, not originally provided with Special Service Message 51235, which was released on December 7, 2022...
  • Differential Control Module Rear (DCMR) - 2021 Expedition Workshop Manual.pdf
  • Differential Electronic Module - Wiring Connector Location Diagram - 2021 Expedition Workshop ...pdf
  • Differential Control Module Rear (DCMR) - Connector C3396 Details - 2021 Expedition Workshop M...pdf
  • Electronic Limited Slip Differential (ELSD) Wiring Diagram - 2021 Expedition Workshop Manual.pdf
rallybug
