Dustin Gebhardt
I need some pointers on where to start looking. I have a 2007 EL Limited 4x4. Recently, I've been hearing and feeling a thump at around 35-42MPH. This hasn't been a normal transmission gear shift, but rather in-between shifts. I can eliminate the noise if I switch from 4A to 2H. If I accelerate gingerly, the noise doesn't happen (or it's so faint that I can't otherwise hear it), but if I accelerate moderately or faster, the noise happens every time. Since this noise only happens in 4A, I'm guessing that it has something to do with the components in the front drivetrain.
I suppose that if I knew exactly what is different while running between 2H and 4A, then I could troubleshoot the issue better. Is the transfer case turning the front driveshaft while in 4H (but the wheel hub are unlocked), but not turning the front driveshaft while in 2H? Or are the wheel hubs locked but the transfer case is disengaged?
Any thoughts?
Any thoughts?
