chuck s
- Joined
- Dec 20, 2006
- Posts
- 1,825
- Reaction score
- 673
Looks like a nice trailer.
Towing at maximum ratings is possible but seldom provides "happy towing". For those buying a truck or SUV ALWAYS get the HD Tow package, it's cheap as a option and although you can add it piece by piece that will be more expensive.
There are dozen of towing "Rules." My personal rule (I made it up!) and the one I recommend for happy towing is the One Ton Rule. This accounts for weights in the truck -- remember every pound in the truck lowers the max towing capacity pound-for-pound -- high summer temperatures (and stuck in traffic), long grades, and higher altitudes. This rule mandates the truck have 2,000 pounds towing capacity than the GVWR of the trailer. In the case of this Jayco that would be 7,500 pounds and you max out at 6,300.
Running the rule the other way don't buy a trailer with a GVWR of more than 4,300 pounds a Ton less than your max towing capacity.
Can you get away with 1,000 pounds? Probably but you may be flogging the poor beast in some conditions. Fit a larger transmission cooler, larger radiator, and add a trailer brake controller. If you can get the Ford controller to work it's wonderful. You'll need a WDH -- recommend the Equalizer (brand). You won't need upgraded brakes or suspension parts -- nor will they increase towing capacity. The trailer brakes will handle the trailer that's why they're there.
What often turns out to be critical is the combined weight of passengers and cargo. Using the 1504 pounds in the pictured sticker and the critical tongue weights of conventional trailers which must be in the 10% - 15% of the trailer's weight so there's a minimum of 560 pounds but more likely the 630 that maxes out the truck and reduces the CCC to about 900 pounds for passengers, dogs, and the like.
Please, everyone, stop mentioning "dry weights." These are pure fiction and trailers often leave dealer's lots several hundred pounds heavier once batteries and propane cylinders -- and other "stuff" are added.
I'm currently towing a 6,000 pound travel trailer behind my 9,300 pound rated 2017 Expedition. Not once have I wished I had less towing capacity.
-- Chuck
-- Chuck
