TSB 22-2295 - 2022 Expedition/Navigator built on or before 13-May-2022 + Other Models - Various Driver Assistance Feature Concerns And/Or IPMA DTCs
HazBeen
Great Lakes
TECHNICAL SERVICE BULLETIN
Various Driver Assistance Feature Concerns And/Or IPMA DTCs B1578:78, U3000:49, U3000:89, U2107:68, C1001:54 And/Or C1001:78
22-2295
21 July 2022​
This bulletin supersedes 22-2109.
Model:
Ford
2022 Expedition
Built on or before 13-May-2022
2021-2022 F-150Built on or before 19-May-2022
2021-2022 Mustang Mach-EBuilt on or before 04-May-2022
Lincoln
2022 Navigator
Summary
This article supersedes TSB 22-2109 to update the vehicles affected and Service Procedure.
Issue: Some 2021-2022 F-150, Mustang Mach-E and 2022 Expedition/Navigator vehicles may exhibit various driver assistance system warning messages or inoperative features and/or diagnostic trouble codes (DTC) U3000:49, U3000:89, U2107:68, C1001:54 and/or C1001:78. DTC B1578:78 may also set after an image processing module A (IPMA) on-demand self test is performed. This may be due to software in the IPMA. To correct the condition, follow the Service Procedure to reprogram the IPMA to the latest level.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
• One of the following vehicles:
- 2021-2022 F-150 built on or before 19-May-2022
- 2021-2022 Mustang Mach-E built on or before 04-May-2022
• At least one of the following concerns:
- Front Camera Fault Service Required message
- Pre-Collision Assist Not Available message
- Reverse Brake Assist Not Available message
- Lane-Keeping System Fault Service Required message
- Collision Warning Not Available message
- Check Front Park Aid message
- Check Rear Park Aid message
- Blind Spot System Fault message
- Adaptive cruise control inoperative
- Auto high beams inoperative
- Traffic sign recognition inoperative
- Front windshield camera alignment routine fails to complete
- DTC B1578:78, U3000:49, U3000:89, U2107:68, C1001:54 and/or C1001:78
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
DescriptionOperation No.Time
2021-2022 F-150, 2022 Expedition/Navigator: Retrieve DTCs Check For Download And Run The IPC Update App (Do Not Use With Any Other Labor Operations)
222295A​
1.0 Hrs.​
2021-2022 Mustang Mach-E: Retrieve DTCs Check For Download And Run The IPC Update App (Do Not Use With Any Other Labor Operations)
222295B​
1.2 Hrs.​
2021-2022 F-150, 2022 Expedition/Navigator: Retrieve DTCs, Check For Download And Run The IPC Update App, Reprogram The IPMA And PSCM, Perform IPMA Alignment Procedure Includes Time To Perform The Appropriate Camera Alignment (Do Not Use With Any Other Labor Operations)
222295C​
3.2 Hrs.​
2021-2022 F-150, 2022 Expedition/Navigator: Retrieve DTCs, Check For Download And Run The IPC Update App, Reprogram The IPMA, PSCM And CCM, Perform IPMA Alignment Procedure Includes Time To Perform The Appropriate Camera Alignment (Do Not Use With Any Other Labor Operations)
222295D​
3.4 Hrs.​
2021-2022 F-150, 2022 Expedition/Navigator: Retrieve DTCs, Check For Download And Run The IPC Update App, Reprogram The IPMA, PSCM, CCM And CMR, Perform IPMA Alignment Procedure Includes Time To Perform The Appropriate Camera Alignment (Do Not Use With Any Other Labor Operations)
222295E​
3.9 Hrs.​
2021-2022 Mustang Mach E: Retrieve DTCs, Check For Download And Run The IPC Update App, Reprogram The IPMA And PSCM, Perform IPMA Alignment Procedure Includes Time To Perform The Appropriate Camera Alignment (Do Not Use With Any Other Labor Operations)
222295F​
3.4 Hrs.​
2021-2022 Mustang Mach E: Retrieve DTCs, Check For Download And Run The IPC Update App, Reprogram The IPMA, PSCM And CCM, Perform IPMA Alignment Procedure Includes Time To Perform The Appropriate Camera Alignment (Do Not Use With Any Other Labor Operations)
222295G​
3.5 Hrs.​
2021-2022 Mustang Mach E: Retrieve DTCs, Check For Download And Run The IPC Update App, Reprogram The IPMA, PSCM, CCM And CMR, Perform IPMA Alignment Procedure Includes Time To Perform The Appropriate Camera Alignment (Do Not Use With Any Other Labor Operations)
222295H​
4.0 Hrs.​
Repair/Claim Coding
Causal Part:14G647
Condition Code:04
Service Procedure
NOTE: When performing the IPMA software update additional modules will receive software updates. Depending on vehicle features, the coordinated software update includes the IPMA, power steering control module (PSCM), cruise control module (CCM) and/or camera module - rear (CMR).
1. If DTC U3000:49 is present in the IPMA and the vehicle also exhibits indications of a low battery voltage condition such as DTC U3003 present in other modules or an engine no crank/no start concern, check for OASIS messages for low battery voltage and continue with diagnostics for low battery voltage. To clear the DTC, download and run the Reset the Image Processing Module A (IPMA) Learned Values application in Ford Diagnosis and Repair System (FDRS). Then run the Image Processing Module A (IPMA) Alignment application immediately after. Proceed to Step 2.
2. If DTCs U2107:68 and/or U3000:89 are present after performing an IPMA self-test, clear the DTCs and only perform diagnostics for U2107:68 and/or U3000:89 if these DTCs set outside of an IPMA self-test. Proceed to Step 3.
3. Is the vehicle an F-150 (non-Lightning) built on or before 28-Mar-2022, Expedition/Navigator built on or before 18-Feb-2022 or a 2021 Mustang Mach-E?
(1). Yes - proceed to Step 4.
(2). No - proceed to Step 7.
4. Reprogram the IPMA using the latest FDRS software level. Follow all on-screen instructions carefully to complete all coordinated module software updates.
5. Perform the Ford Diagnosis and Repair System (FDRS) Image Processing Module A (IPMA) alignment procedure.
6. Perform the appropriate FDRS camera alignment procedure.
(1). For vehicles equipped with 360 degree cameras, perform the IPMA - 360 Degree View Camera Alignment procedure.
(2). For all other vehicles, perform the IPMA - Pro Trailer Backup Assist Camera Alignment procedure. This procedure should be performed on all vehicles without 360 degree cameras, even if the vehicle is not equipped with Pro Trailer Backing Assist™ (PTBA).
7. Run the IPC-Instrument Panel Cluster (IPC) Configuration application in Ford Diagnosis and Repair System (FDRS).
  • TSB 22-2295 - 2022 Expedition-Navigator built on or before 13-May-2022 + Other Models - Variou...pdf
Lou Hamilton
Maryland
Anyone have this done on theirs yet? Mine goes in on 15 September due to the Reverse Brake Assist Not Available message.
Lou Hamilton
Maryland
Had this completed on Friday. After the re-program, it still showed the scrteen error and another one. They had to reset the instrument cluster, as well.
Now, no more errors and the Reverse Brake Assist works (although I have it turned off because it is too sensitive for me).
Huntsw1
Fishers, IN
Did this help with your lane center assist? If I use mine I have to jerk the steering wheel every couple of seconds or i get the hands on wheel error
rd618
new york
By far the most annoying feature is the constant “hands on wheel” when you never take your hands off the wheel.
Lou Hamilton
Maryland
I don't use the Lane Center Assist. I feel that I am constantly battling the computer from where I feel more comfortable driving within the lines.
cw13
canada
22-2295
21 July 2022​
Model:
Ford
2022 Expedition
Lincoln
2022 Navigator
Summary
Labor Times
222295A​
1.0 Hrs.​
222295B​
1.2 Hrs.​
222295C​
3.2 Hrs.​
222295D​
3.4 Hrs.​
222295E​
3.9 Hrs.​
222295F​
3.4 Hrs.​
222295G​
3.5 Hrs.​
222295H​
4.0 Hrs.​
Repair/Claim Coding
Causal Part:14G647
Condition Code:04
Service Procedure
I’ve got the warning adaptive cruise control sing recognition not working warning. Also my sync4A screen is black and won’t turn on. I am waiting for a new AIPM but on Back order amd it’s been 6 weeks already. Is this TSB requiring AIPM reset done on the screen or do they plug directly into it? I’ve asked to attempt to reset /reprogram the Aipm to fix black screen but they are reluctant!! I have a hunch the over the air update has caused my issue as 1 day after it went blank I received a message in the ford app that an update was completed??
