TSB 23-2143 - 2018-2020 Expedition/Navigator built on or before 11/30/2019 - 3.5L EcoBoost - Cold Start Ticking/Tapping/Rattle, Possible No Restart...
HazBeen
Great Lakes
***Partial TSB description - For full information, see attached PDF document***
TECHNICAL SERVICE BULLETIN 23-2143 - Released May 04, 2023
3.5L EcoBoost - Cold Start Ticking/Tapping/Rattle With Possible No Restart During Auto-Start-Stop Operation
This bulletin supersedes 22-2200.
Model:
Ford - 2018-2020 ExpeditionBuilt on or before 30-Nov-2019
Ford - 2017-2020 F-150, 3.5L EcoBoost EngineBuilt on or before 30-Nov-2019
Lincoln - 2018-2020 NavigatorBuilt on or before 30-Nov-2019
Summary
This article supersedes TSB 22-2200 to update the production fix date, Action statement and customer symptom.
NOTE: Certain parts may now be reused for this repair. Refer to the Service Procedure for details.
Issue: Some 2017-2020 F-150 and 2018-2020 Expedition/Navigator vehicles built on or before 30-Nov-2019 and equipped with a 3.5L EcoBoost engine may exhibit a ticking/tapping or rattle type noise from the top front cover area of the engine on initial start-up after a cold soak of 6 hours or more that may last for 2-5 seconds. Some vehicles may also exhibit an intermittent condition with no auto restart during auto-start-stop operation with or without diagnostic trouble code (DTC) P164C present in the powertrain control module (PCM). This may be due to a worn variable camshaft timing (VCT) unit. To correct the condition, follow the Service Procedure to replace the VCT units.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
• One of the following vehicle lines:
- 2017-2020 F-150
• Built on or before 30-Nov-2019
• 3.5L EcoBoost engine
• Customer symptom of ticking/tapping or rattle noise from the front cover area after a cold start
NOTE: Dealers should only order parts for customer vehicles that require repairs. Because of parts constraints, dealers may experience situational short-term backorders on some parts. Customers should continue to drive the vehicle while parts are on order.
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Emissions Warranty/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/Emissions Warranty/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
DescriptionOperation No.Time
2017-2020 F-150 3.5L EcoBoost: Replace All Four (4) VCT Units (Do Not Use With Any Other Labor Operations)
232143A​
9.6 Hrs.​
2017-2020 F-150 Raptor 3.5L EcoBoost: Replace All Four (4) VCT Units (Do Not Use With Any Other Labor Operations)
232143B​
9.7 Hrs.​
2018-2020 Expedition: Replace All Four (4) VCT Units (Do Not Use With Any Other Labor Operations)
232143C​
9.8 Hrs.​
2018-2020 Navigator: Replace All Four (4) VCT Units (Do Not Use With Any Other Labor Operations)
232143D​
9.8 Hrs.​
Service Procedure
1.
Replace all 4 VCT units. Refer to Workshop Manual (WSM), Section 303-01. Do not replace any additional VCT or engine timing related components not included in the Parts List.
(1). It is not necessary to remove the 2 left valve cover camshaft position (CMP) sensors.
(2). All the VCT solenoid and spark plug tube seals require inspection, but not all require replacement.
  • TSB 23-2143 - 2018-2020 Expedition-Navigator built on or before 11-30-2019 - 3.5L EcoBoost - C...pdf
PalosX
