What to look for when buying a gen 1 expy
nvycrmn
Springville, IA
i will tell you what to look for when buying and expy....a different truck! hahah. I love my expy but I DO NOT love changing the spark plugs on this f-ing thing! Nor do I have the patience, so now I have to pay somebody to change them, very upset about this!
KWT2000
NINE MILE FALLS
all suspension bushings for cracking and rott, saggy coil springs, rear pinion seal leak, oil cooler lines leaking, tie rods, idler and pittman arms.
Biged1968
St C. Ohio
ac lines rusted out at the ac compressor, weak shocks, worn hardware kit on rear disc brakes and do not even try to use cheap rear pads on these things, and check the heat shield above the driver side cat , they rust,come loose and rattle and ting.
put never seize around the front hubs if you have factory aluminum wheels
2000eb
spark plugs where fairly easy bout an hour or so just follow the steps people have already sent links of when doing the spark plugs and it isnt that bad at all
zets101
Vermont
PFFFFT! Bull! I changed mine, hardest spark plug job I have ever done in my life! Don't even get me started on plug #4 either, the one that is wrapped up in heater hoses.
mlself
