Where to find the door code for the keypad?
johnboneske
Ohio
On my 2003 EB I'd like to use the keypad on the drivers door sometimes for the keyless entry. How/where do I find the code for it? Thanks!
ExplorerTom
Colorado
On my 2000, it's on a box on the firewall under the driver's side printed on a sticker.
os1kne
Atlanta
Not sure, but if not in the location above try looking in the compartment where the jack is stowed.
docraymund
philippines
If you have two programmed keys for your truck you could insert the first key and turn it to on position. Then turn it off and remove. Insert the second key and switch to on. The factory code will be displayed briefly in the gauge cluster.
GalaxyPilot
Enid,OK
in the cab, underneath the dash. May need to pull a panel or two but nothing complicated
scoot0073
Georgia
On my 03 Expedition EB 4x4 the code is on a flat black box under the dash on the passenger side kicker panel above the fuse panel..
Sent from my Nexus 6P using Tapatalk
