Which OBD 2 hardware and app
Flexpedition
midwest
If you are troubleshooting and fixing in your driveway or garage, you will appreciate the size of your laptop screen. I have a Michael Capellas era Compaq Presario that is dedicated to garage duty.
If you are wanting to drive around and monitor vitals then BT via your cell is the way to go.
Not really a right or wrong way.
Adieu
SoCal
You know post-Compaq-era laptops usually got bluetooth? Oh and tablets too
CertusExpo
Customizing trucks since I was 7 with my Legos
Fort Worth, TX
I've had a generic BT OBD II scanner with TorquePro installed on a dedicated $40 FireTab since mid 2016. No problems with either.
Lately though. I've been thinking about getting BlueDriver because it's a matched set, reader and app plus it/they claim it also reads ABS and transmission codes which TorquePro doesn't.
Denethor
Durham, NC
I have two generic ELM327 bluetooth adapters, paid less than $10 for them, never had an issue and used on many cars and trucks with Torque Pro.
J Ski
3.5plati
VA
So the generic ones will let you use Forscan to disable the bulb out hyper flash too?
ExpeditionAndy
Fort Wayne, Indiana
They might, you just have to try them to see if they are compatible with FORScan. You can go on their site www.forscan.org to see the specifications. You will also have to register for the free license to be able to make programming changes.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
In order to program Ford Modules, whatever is connected to the OBDII port must support the MSCan protocol. If it does it will work with FORScan on the PC.
