Window switch haywire
kenstang
NY
2017 Expedition EL Limited. When I go to put down my windows, using any window switch, while the truck is running, the truck chimes that the drivers door is open, the interior lights come on and the running boards deploy. It’s an intermittent issue that started yesterday. Happened from the drivers side door and from the passenger side as well. I am assuming it’s a computer error?
Yupster Dog
Super Moderator
Super Moderator
Have seen others with this problem in the same spot. Should be the first place you should look if you are having problems.
Thanks Ken for the follow up.
Welcome to the forum
PalosX
