Seatbelt Reminder disable procedure not working on '22
texevora
DFW
On my previous '19 Expedition I was able to disable the seatbelt reminder warning chime. Trying to do the same with my '22, but not having any success following the factory instructions on page 52 of the owner's manual. In short, the seatbelt warning light never switches off in Step 2, so I'm unable to complete the rest of the procedure (just proceeding with the instructions and ignoring the seatbelt warning light not turning off also doesn't do anything).
FACTORY INSTRUCTIONS
Make sure that:
• You set the parking brake.
• The transmission is in park (P).
• The ignition is off.
• You close all vehicle doors.
• You unfasten the driver and front passenger seatbelts.
1. Switch the ignition on. Do not start the engine.
2. Wait about one minute until the seatbelt warning light switches off. After Step 2, wait an additional five seconds before proceeding with Step
3. Once you start Step 3, you must complete the procedure within 30 seconds. 3. For the seating position you are switching off, fasten then unfasten the seatbelt three times at a moderate speed, ending in the unfastened state. After Step 3, the seatbelt warning light switches on.
4. When the seatbelt warning light is on, fasten then unfasten the seatbelt. After Step 4, the seatbelt warning light flashes for confirmation. This switches the feature off for that seating position if it is currently on. This switches the feature on for that seating position if it is currently off
Anybody know how to do this successfully on the '22s?
Rob6805
I did read on another thread that folks with 22's could not get it today work either. It worked on my 21.
Ross583
Make sure that:
Did you ever have any luck? Not working me either.
Nope. Still stuck.
The printed owner’s manual that came with my new 2015 Expedition Limited had numerous incorrect instructions and photographs or illustrations in it.
I have never owned a vehicle with such a poorly written and illustrated owner’s manual.
It sounds as though Ford still can’t provide an owner’s manual that is accurate.
Ross583
Nope. Still stuck.
Ok I got it to work here the instructions I used.
1.
Before starting the procedure, make sure your parking brake is on.
2. Get inside of the driver's seat and close the door.
3. Turn the ignition to ON but not start (key position 2, or press push to start button
without your foot on the brake if you have a push to start button).
3. Wait 5 seconds, then buckle and unbuckle the seatbelt 3 times with a 1 second pause
between each buckle. Wait 4 seconds, then buckle and unbuckle again. The orange/red
seatbelt warning light should flash a couple times indicating that the procedure worked
and was completed successfully.
5. Voila, if that didn't work, try repeating the procedure with the parking brake OFF.
T
texevora
DFW
@Ross583 , you sir, are a gentleman and a scholar.
That worked! Took me about half a dozen tries, eventually it worked (with the parking brake off).
Thanks!
Ross583
1.
Thanks!
For Passenger Seat:
1. Same thing, make sure parking brake is on.
2.
Grab another person.
3. Sit in the driver's seat, have your helper sit in the passenger seat, and close the doors.
4. Turn the ignition to ON but not start (key position 2, or press push to start button
5. Have your passenger do the same procedure listed in step 4 of the driver's seat
procedure or do it for them as they are sitting (Wait 5 seconds, then buckle and
unbuckle the seatbelt 3 times with a 1 second pause between each buckle. Wait 4
seconds, then buckle and unbuckle again. The orange/red seatbelt warning light should
flash a couple times indicating that the procedure worked and was completed
successfully.)
6. Voila, if that didn't work try repeating the procedure with the parking brake OFF.
For some reason, to disable the passenger seatbelt alarm, it requires both a driver and
passenger to be sitting in the vehicle.
Overtow
CLEVELAND
Confirmed this procedure worked on the first try for my 2018 XLT:
This is going to stop soooo many arguments....thanks Texevora!!
Make sure that:
turro15
