leaky passenger side valve cover I think
wpatters1229
Pleasant Hill CA
I had a miss on the number two plug. By swapping coils and then plugs it was determined to be the spark plug. The problem was that both plugs had oil all over them when I pulled them out. The number 1 was the worst. I cleaned out all the oil and adjusted the gap on the two plugs and all is good. QUESTION: I do not think the valve cover is leaking but in case it is do they make something I can add to the oil to make that gasket swell to help stop any leak or is this maybe the head gasket leaking? I cannot remove the valve cover since I am 77 years old and my hands have a bit of arthritis. From what I have read it is a tough job. I will send it to a shop to get new plugs since that is also a tough job.
Any ideas on this?
W
wpatters1229
Pleasant Hill CA
Forgot to say this is a 2000 with 5.4l and 147000 miles. Runs fine in all other aspects of the engine. No loss of water and no oil drips on the driveway. Hardly uses any oil between changes and has plenty of power. Just never seen oil around a plug like this.
Hamfisted
Ft Lauderdale
About the only sealer worth trying is that AT-205. It's a mineral spirits consistancy and will mix with your oil without issues. Just depends on how bad your gaskets are. Sometimes you just can't overcome age and heat damage. You can find the AT-205 at any AutoZone, or even order it on Amazon if you like. Ask the shop how much they would charge you to replace the gaskets.
W
wpatters1229
Pleasant Hill CA
I just got a bottle from Amazon. I used a bottle in a spray bottle to quiet the bushings on my jeep. They dry out and this is the only thing that works. Just spray all over the bushings. I will put this new bottle into the oil and then see what happens.
W
wpatters1229
Pleasant Hill CA
Last update. Since spraying carb cleaner in the well where the spark goes and cleaning the plug and the boot for the coil there have been no more missing. Today I took off the coils and using my inspection camera stuck it down into the shaft where the spark plug is located and saw no more oil on either plug. The only conclusion I can come up with is that someone adding oil must have spilled some into the ports that hold the plugs. The car runs fine so will leave it alone. I eventually will have to have the plugs replaced but not doing that myself as it looks like a mess to deal with getting to the back passenger side plugs. Driver-side plugs don't look that bad to get to but I will pay a pro who has done this before to do it. I just have to find a good mechanic who has done it before.
AksoBruce
Replacing the right bank valve cover gasket is a daunting task for certain. With a voice of experience, the most difficult thing about is the harness laying across it. Mine is a '97, so I'm not exactly certain how it is routed on yours, but mine was a witch with a capital B. The left bank was only slightly less bothersome as it has the EGR tube in the way. Definitely NOT one of Ford's better ideas.
I can feel your pain with the arthritis, Brother. I am a few years behind you at 62 and I was diagnosed with RA when I was 21. I have also been bending wrenches professionally since I was a kid. It hurts every day.
