A. What type of spark plug issue?
B. Why does the engine have to be removed?
C. What repairs will be done for the $2,000.00?
A) I'm not a mechanic by any means, but am fairly knowledgeable of how IC engines work, and the only spark plug issue I know of that would make that sound is if one just basically exploded from the inside out....now that WOULD make a very loud sound indeed..as well as cause significant damage to the insides of the cylinder if the engine continued to run afterward.... however, a failing coil pack could also make a loud sound too..
B) If the shop says the engine needs to be removed JUST to replace a spark plug, then either:
1) They have a legitimate reason to believe it was damaged during the incident, or
2) They're out their friggin mind and don't know what they're doing, even though there are a few hoses/tubes that need to be disconnected/moved out of the way to get the rear plugs, or
3) They believe they've found a sucker who they can rip off big time....
I'm leanin towards either #2 or #3....
Now let me explain how I know this...
A) I also own a 011 EL Limited that is due for new coil packs & plugs
B)
2 local ford dealers quoted me $860-900 for the job last week, including all new Ford/Motorcraft parts, and had no problem explaining exactly what would be involved to get 'er done....
C) My
other trusted shop of 10+ years quoted me $520 last week for the same job (all labor)
if I buy/bring the parts, and they concurred on what needed to be removed to make it happen....
But as always, YMMV, and you gotta go with your gut feelings on this matter, so good luck & please post back here with the results if you can..
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
