HazBeen
*** This is an Advance Notice. This post will be updated when additional information becomes available ***
Supplemental information on involved component(s) from 2018-2020 Expedition Workshop Manual:
Airbag and Seatbelt Pretensioner Supplemental Restraint System (SRS) - Overview
The Restraints Control Module (RCM) continually receives and monitors inputs from the Occupant Classification System Module (OCSM) and various other hard-wired switches and sensors. If the RCM detects a sudden vehicle deceleration and/or lateral deceleration based on the information received from the various sensors and determines that deployment is necessary, it applies voltage and current to deploy the appropriate SRS components.
Seatbelt Anchor and Pretensioner
The seatbelt anchor pretensioner is a pyrotechnic device that removes excess of webbing slack from the seatbelts when deployed. One is included as part of each front row outboard seatbelt assembly and cannot be serviced separately.
Seatbelt Retractor and Pretensioner
The seatbelt retractor and pretensioner is a pyrotechnic device that removes excess of webbing slack from the seatbelts when deployed. The retractor and pretensioner are serviced together with the front row outboard seatbelt assembly.
FordParts.com System Illustration
