No power at fog light module 2019
Yupster Dog
Super Moderator
Super Moderator
The reason for that,
Some states only let you burn 4 lights forward facing at a time.
(Commonwealth of Virginia being one)
So its low beams with fogs,
or high beams with low beams.
Left Coast Geek
Mid Left Coast
2019 Ford Expedition Limited
Factory led fog lights
Ive recently noticed that neither one of my fog light are working. Green indicator on dash illuminates but neither light comes on. I checked to see if the module and get 12v and they’re not getting any power.
What should I check? I have forscan and adapter which I used to turn on Bambi mode in the drop down menu.. this is what led me to realize that neither was working in any scenario
not sure what module you are talking about, but my 2019 wiring diagrams show the fog lamps are driven directly from the BCM...
I note, there's no seperate Halogen vs LED drawings for the fogs. There ARE two separate drawings for the headlights, so either all fogs are LED, or its the same wiring, they just use different lamps.
