Broncoholic
So the new battery was toast and I got it replaced under warranty. I got the factory amp and replacement sub from @whtbronco - MUCH appreciated! I swapped the amp out and it drove my factory sub pretty good, so my amp was definitely shot/shorted out inside. With that confirmed, I had to disassembly the entire side to swap the sub because my factory equipment was dual voice coil at 2 ohms, but @whtbronco's is single line at 4 ohms. A couple hours later and everything is back to good... actually a little better I think with that MTX!
