Randy-IA
It was interesting. Not depressing. I believe that mine might have the broken forward drum.Well this probably won't make you feel any better, but it's a good read.
4r70w no forward gears, only reverse. help needed.. - Ford Truck Enthusiasts Forums
Clutch, Transmission, Differential, Axle & Transfer Case - 4r70w no forward gears, only reverse. help needed.. - I have used this site for a long time but this is my first time having to post. I have a 98 expedition with a 4.2 liter 4x4 and what I believe to be a 4r70w transmission (u code on...www.ford-trucks.com
It's been a year since it broke so I need to get back to it. Cool front just went through with noise and badly needed moisture finally. I have to pick an implement I won at an auction before I go to work tomorrow and I have to work a 12+ hour shift on Saturday. I should be able to look at recharging the battery (if it's not ruined) on Sunday while i work on the tractor steering or the avalanche (one of them can sit there and charge it up some). It's got a full tank of year old gas since I filled it up about 25 miles before it died.
I didn't own an automatic trans until I was about 40 years old because I believed them to be unreliable...
I also have a good running albeit seriously rusty Ram 2500 that the OD is bad in. I bought a donor truck that has the same trans and 4wd box in it but can't find the time to swap that out either.
I never thought I was hard on transmissions. But I'll take a manual any day now. Easy to work on, easy to remove, don't overheat, only one clutch disc to deal with. I need to get my '75 shortbox 4x4 back on the road. It has a well built 355 with a sm465 in front of a 205 t-case. It was a project mud racer that I lost interest in. I didn't get too far to the "racing" mods other than the engine and clutch.
