Perfection! Worked like a charm on my 2024 ExpyOk I got it to work here the instructions I used.
1.
Before starting the procedure, make sure your parking brake is on.
2. Get inside of the driver's seat and close the door.
3. Turn the ignition to ON but not start (key position 2, or press push to start button
without your foot on the brake if you have a push to start button).
3. Wait 5 seconds, then buckle and unbuckle the seatbelt 3 times with a 1 second pause
between each buckle. Wait 4 seconds, then buckle and unbuckle again. The orange/red
seatbelt warning light should flash a couple times indicating that the procedure worked
and was completed successfully.
5. Voila, if that didn't work, try repeating the procedure with the parking brake OFF.
