WHOISMOOTOO
OK I KNOW IVE BEEN SAYING ILL POST THIS FOR A WHILE SO HERE IT IS
FIRST I ORDERED MY 3 LED STRIPS FROM EBAY (x4=ALL 4 DOORS)
http://cgi.ebay.com/ebaymotors/2-x-...r_Truck_Parts_Accessories&hash=item27b4e51952
it was around $11 for all 4 shipped, it takes 2 weeks to arrive(comes from hong kong) if you want it sooner then it will be more expensive to purchase it from the states or autozone about $10 for 2 strips.
next step is to have tools handy if you dont have a set of those torx keys or screw drivers, get one! anything you do on your truck you will need them!!
torx set
flat tip + cross tip screwdriver
high temp hot glue gun (or gasket sealant if your cheap)
7/16 wrench and socket
at least 5" extension
7mm socket
electrical tape
18 gauge wire
drill w/ 5/16 drill bit (or big enough to drill the hole for the bulb you bought)
*knife
roughly 2-3 hours (if you never removed your panels before)
**************************************make sure your windows are all the way up at this time*******************************************
identify the power source, i wanted them to turn on when i hit the unlock button. ive got the eddie bauer with the courtesy lights under the side mirrors so thats what i tapped into. if you dont have them on your trucks find another 12v source or possibly run them straight to the battery with a toggle switch (this way wont turn them on when you hit the unlock button)
fold the mirror forward till you can locate the torx screw (dx10) once you remove it then move the mirror so you can see the clip that holds the turn signal lense to the mirror housung
push the clip down and the outer side of the signal lense will drop out then there is a tab that holds the inner side in place pull down and away from the vehicle.
