jeff kushner
I tried to listen to the vid but I don't have sound on my work putter so I'll listen tonight. FWIW Suzuki had some real issues with pistons crumbling after 30K miles years ago. The cause was found to be too much silicone in the alloy used to make them. The number of heat cycles they could handle was finite as many learned.
Typically, cracked skirts(remember, these aren't the 3" skirts of yesteryear, these are "high & tight" meaning the skirt is very short. What happens is the short skirts concentrate stresses caused by the piston trying to rock. Now, take a cold engine, start it and floor it and you will heat the pistons prior to the cylinder& jacket coming up to temp. This will cause expansion of the pistons, greatly increasing the stresses because they are now constricted in a cold bore......turbo-charging only makes this worse.
I'll post up once i've had a chance to listen at home.
jeff
jeff
