Hi all. I have been spending some time doing research here and elsewhere regarding a lift and new suspension. I am going to be "overlanding" and mountain biking mostly in Colorado from ~ mid July to some point in the Fall, camping at dispersed sites for basically the whole time. I have a 2017 EL Limited 4wd with 97,000 miles. I've done a substantial amount of work including 2 slide out drawers, a roof rack, and an electrical system with solar, alternator charging, and a shore input. I have wanted to do a writeup on this for a while and maybe once I have some good action shots after this trip I will finally do that.
I think I have figured out what I need suspension wise, and I was hoping to present my findings and make sure I am not going to either buy something that won't install or install something that is going to kill me. While I am relatively mechanically inclined, my vehicle knowledge doesn't extend beyond changing oil and brake pads, so all of the information I've been able to gather was from here over the past few days and I am very grateful for all of the extremely knowledgeable people that provide a lot of help here. Onto the subject matter:
Most (or likely all) of this work will be done by a mechanic I trust.
Spacer Lift: ReadyLift 69-2070 3.0'' Front with 2.0'' Rear SST Lift Kit - I know this fits with stock struts and springs, but compatibility with aftermarket is what I don't know for sure.
UCAs: ICON 2004-20 Ford 150 Tubular UCA/Delta Joint Kit (SKU-98500DJ) - I also know this fits with stock struts and springs
Struts and Springs - this is what I am not 100% on.
- Seeing some conflicting information here as to whether or not the springs on Bilstein 5100s will hit the Icon UCA at full extension, and whether or not they are usable with the Readylift kit. My current assessment is that I can use the Readylift kit with the 5100s at the lowest setting. Not sure on clearance with the Icon UCAs though. Also, am I correct that the front spring perches on the stock struts can be removed, but on EL vehicles they are welded in the rear if they are the NIVOMAT version so I will need to find a set of struts with removeable perches from a junkyard? There is only one junkyard reasonably close to where I live and it is not very big so I'd like to avoid this option if they are in fact welded on.
- Other than the Icon coil overs, what are my options for not needing to reuse the spring perches? The next best option for this seems to be KYB SR4456 (front) and KYB SR4515 (rear). I haven't read anything bad about these, aside from some stiffness complaints. I have at least 500 extra pounds in the back third of the vehicle, so maybe extra stiffness is not as big of an issue if true. I've seen multiple posts where people state that they have the KYB's installed with the Readylift kit, but can't find anybody who has these installed with the Icon UCAs so fitment is not confirmed. I think it will fit, but this is not based on anything other than me wanting that to be the case. Any advice on this? I am currently leaning towards the KYB SR4456 and SR4415, but am interested to hear other's opinions.
Thank you for reading my post and have a good day.
~Alex
~Alex
