Ugh_J
Point of order re: tire pressures. An uncle that works in tire design (as a mechanical engineer) mentioned that if you go measure your weight per axle on a scale, you can derive your recommended pressure. The range is 0 PSI to the max listed on the tire's sidewall, and is a linear function of load on that tire. So axle weight / 2, figure out what percentage of the max load rating yours is carrying, and multiply the max PSI by that percentage. I did this when running SUV tires on my Charger and it really worked well. The recommended PSI on the door sticker only applies properly to the OEM tires and possibly others with the same size and characteristics. As soon as you deviate from that to a different size or load range or etc., that number isn't accurate any longer.
And you probably noticed, but load per axle is not a fixed value -- it will change when you hook up a trailer or load up the truck for a trip.
