StreetCreeper
I have a clogged AC condensate drain and decided to try and snake it today.
Due to the angle of the drain and the proximity to all sorts of stuff near it, getting a coat hanger up there and being able get it to bend into the drain without binding up is a real MF'er. Was only able to slide about 4 or 5 inches into her (go ahead and grin – I understand) before it hits something or gets snagged. So I'm not sure if it's just that the coat hanger isn't the best tool for the job, or if I might just already be up against the clog.
Does anyone know how far I should be able to run this coat hanger up inside there if there was no clog at all?
I'm thinking of maybe trying to run some air from a compressor up into it – but I'm not sure if the air pressure could damage anything? I've never had a condensate drain clog before, so anyone with some experience – please feel free to share.
In the pics ( I zoomed in on the second pic), you can see that little black circle way back up in there – that's the drain (not to be confused the obvious drip tube that goes further up to whatever ). Between the drip tube, exhaust and O2 sensor all being right there – it prevents me from even getting close to the drain so I can brace/support the coat hanger as it bends for that initial turn into the drain.
