Adding a subwoofer
z168
Cali
Im going to add a subwoofer to the factory set up. So yes its a stock headunit.
This is what Im adding. nothing fancy just wanted some added bass
I will use a high to low converter to for the signal of the amp. It looks like this
I have 3 questions:
1. Where is the nearest stereo speaker wires in the trunk area to tap into? That way I dont have to run the wires all the way to the dash
2. Where is the nearest remote turn on (antenna wire)? from the trunk area as well so i dont need to run it all the way to the dash
3. Is there a positive terminal junction in the trunk area? (you get the idea...so I dont have to run the positive wire into the engine compartment)
Hampton, VA
#1...rear sub...#2...u have to run the wires...#3...u have to run the wires...it's really not that bad to run them
Holy Roller Christian Car Club (HRC3) National Member...
reefkrazy
ct
do you have a factory sub and amp back there? If so I can snap some pics of what I did. Took sub out and installed kenwood shallow ten inch sub. took out factory amp and put in Rockford fosgate punch 100 amp. ( very small) located in the jack compartment in back.
Z
z168
Cali
Thanks for the replies. I dont have the factory sub unfortunately. I wonder if its prewired...
Yes please snap pics and post
Hampton, VA
Just run the wires...easiest since u don't rear sub to tap into
oblivion
Ontario Canada
I agree with Freeway, your going to have to run power and ground and find some accessory to turn on the amp unless the amp has a turn on circut. In your 2000 its VERY easy to run wires down the channels under the door trim. Luckly you only nee a 100ish watt amp for that so it will be tiny, you can easily hide it behind the panel in the rear pass side.
Z
z168
Cali
Let me pry the factory sub location and see if there are wires I can use there. But I agree thinking about it it doesnt look hard since the door sills easily come out.
Hampton, VA
If u have factory sub tap into that...I have pics of how I used to have it
vincentesq
Bakersfield CA
Can you please post pics and the model number of the sub and amp? I have a subwoofer in the back and would love to see more info. Thanks.
