Im going to add a subwoofer to the factory set up. So yes its a stock headunit.
This is what Im adding. nothing fancy just wanted some added bass
I will use a high to low converter to for the signal of the amp. It looks like this
I have 3 questions:
1. Where is the nearest stereo speaker wires in the trunk area to tap into? That way I dont have to run the wires all the way to the dash
2. Where is the nearest remote turn on (antenna wire)? from the trunk area as well so i dont need to run it all the way to the dash
3. Is there a positive terminal junction in the trunk area? (you get the idea...so I dont have to run the positive wire into the engine compartment)
I have 3 questions:
