duneslider
I was thinking, while trying to fall asleep last night. I have not seen any brackets that mount an antenna to the roof rack cross member, but I have a spare set of bolt holes on the roof rack where you can move the rear cross member. I could fashion a steel plate to bolt in that spot that would mimic a roof mount and allow a mag mount. It would be near the edge, so less than ideal, but, I think, better than the other options. Interested in yall’s thoughts.
I have thought about finding a way to attach something to the roof rack also, like you are describing. I have the lip mount on my jeep and really like it but I am not ready to put that on the expedition yet.
I don't have the garage door clearance for it to work well mounted anywhere on the expedition.
I would still recommend you use a more secure mount than the mag mount. You could still use your same theory but get an nmo mount and mount that to the plate. It will require a little more work to take on and off but I think you will be happier with the performance. The comet sbb-5 has a fold over mast that you could easily just fold over and maybe not have to remove.
I haven't used a mag mount in a long time but everyone I used would slide around on the paint at high speeds, or tip over at speed. Your bracket that just attached with 2 bolts would be pretty easy to remove and would give the antenna a much better ground.
