thanks loki - just the person i was looking for a reply from. i’ll take this as the best choice.These are the best option for the 2nd Gen 3.5...
Set of 6 NGK LTR7BHX (95605) Spark Plug | ZFG RACING LLC
NGK Ruthenium HX is designed for newer engines which demand high ignitability. Projected Square Platinum Electrode (PSPE) design promotes spark energy concentration and ignites a wider range of air-fuel ratios, offering improved performance in rich or lean engine conditions. 0.4mm Ruthenium...www.tunedbyzfgracing.com
If stock do .031 Gap, if tuned, .028 is a good starting point. They will come gapped.
How many miles?thanks loki - just the person i was looking for a reply from. i’ll take this as the best choice.
anything aside from boots (pen) that i should also do at the same time?
43kHow many miles?
I just received these exact ones from Rockauto.com on Wednesday. About $8 each. After installing them, I think it resolved an issue of occasional shudder while idling. I will give it another week of driving to determine for sure.These are the best option for the 2nd Gen 3.5...
Yep! Advantage of getting them through ZFG, is they are gapped to exactly what they need to be. Little piece of mind. The gap is just as important as the plug itself.I just received these exact ones from Rockauto.com on Wednesday. About $8 each. After installing them, I think it resolved an issue of occasional shudder while idling. I will give it another week of driving to determine for sure.
