Tys expedition
Has anyone removed the ccd shocks and used an aftermarket coil over?
If yes did it generate problem codes?
If no one has done this yet I’m considering trying to remove the solenoid from the shock body and see if leaving it plugged in even though disconnected is a viable work around allowing for aftermarket coilovers.
if you have actual knowledge of a work around or delete method please let me know below. Thanks
