Definitely happy with it. It works like its new again.
I didn't realize that the brake pedal mechanism worked off a drive cable from motor which is attached to the gas pedal. You are right it really is a very simple operation if you are thin and flexible enough to maneuver in the footwell.
Now you need to see if you can make gears for the blend door actuator and the other A/C system dampers.
