Had some time today so I pulled the drivers side valve cover. No easy task on this!!
Found about what I expected. That's is nothing due to the intermittent nature of it and it only doing it while hot. No signs of broken springs, bad followers or lash adjusters. Debating where to go from here.
Could theoritically set it up to run without the valve cover present but would be a pita as I would have to assemble and disassemble again just to re-install valve cover. Bit worried about getting oil everywhere while she is running not to mention exposing the crankcase to dust, pollen, etc.... But if it was a rocker, lash adjuster, maybe even valve guide I may be able to see or pinpoint it easier with valve cover removed.
One thing I did notice is while cranking the timing chain tensioner on that side is very active. It moves in and out quite dramatically. I can only assume this is normal but have no real evidence to tell me one way or the other.
