stamp11127
Check for power on pin 7 of the speed control. It is located next to the master cylinder on the driver inner fender. It is hot in run.
The are additional tests that deal with the airbag sliding contacts and speed control switches in the steering column. I strongly suggest getting the Ford wiring manual for this since you will be close to the airbag. If you probe the wrong connector you chance setting it off.
http://www.youtube.com/watch?v=v66Y-jtDaGw
If you wish to continue without a manual I'll tell you what I can. You should be able to get one off ebay cheap.
