How complete of a coolant flush is needed?
J
jslt
Bellingham
So I've got a few drives around town with subsequent hose flush cycles. The car is running well and heater lines are getting nice and hot, but lots of rust flakes and debris coming out of the block drain each time I flush. I've decided that I am going to hook up an inline coolant filter (Wix canister style) before the heater core hoses and just worry about keeping the debris out of my heater cores.
Can anyone tell me (or point me to a diagram) that shows what direction coolant flows through the hoses? My assumption is that the coolant flows up through the block and out the top to the upper radiator hose and the heater core hose at the front side of the engine. The two hoses in my photo with the arrows are the outlet hoses right? My plan is to put the coolant filter on the heater core outlet hose (top left).
jr1under
Aiken, SC
I have this picture(which might even have come from this forum) in my NeedToKnow folder. It's for either a Gen1 Exp or Gen11 F150.
J
jslt
Bellingham
Wow, thanks jr1under! I had a completely incorrect understanding about the general flow through the rest of the engine. I think my plan to install the coolant filter on the 1 (inlet to heater core) line will work still though.
J
jslt
Bellingham
I'd like to see the filter install if you have pictures to show.
Just got it done this afternoon! Here are the photos. I need to shorten the outlet line a few inches, but I wasn't sure where the filter manifold would end up. I was actually able to find a hole to bolt it to right where it is, so its nice and solid. I hooked up the front heater core as well and I can say that having heat again is glorious!
However, I have noticed that I don't seem to be getting much (if any) flow to the rear heater lines now. I suspect that the filter is reducing the line pressure too much for the rear.
I am using the OEM hose with the flow restrictor. I'm thinking maybe I should cut out the flow restrictor since I have a filter acting as a flow restrictor now. Thoughts on that idea?
jr1under
Aiken, SC
I understand now how you installed the filter in the hose between the water pump and where it T's off to the heater cores. I also understand Bernoulli's principle but, even though it's the internet, I won't pretend to know what you should do here.
Petesexpy
Delaware
Is this an oil or water filter? I mean I know what its doing, but is it manufactured to filter water or oil?
J
jslt
Bellingham
It is specifically for coolant, it’s this wix filter: https://www.oreillyauto.com/detail/...er/b2f9e5157c1e/wix-coolant-filter/wix0/24070
I read about it on a Jeep forum. It seems like a common modification they do.
I pulled the filter off today to check it. Already full of crap! I think I’m going need to replace it frequently while the rust flakes are still coming off. I did remove the flow restrictor on the inlet hose and that definitely made more water flow to the rear hose. I’m going to run it for a few weeks doing regular flushes then replace the filter before I put coolant in.
