Max, it is possible you have a bad valve seal and that is causing you to burn oil (may not see the blue cloud coming out the rear of the truck complements of the cats) mixed with a stuck lifter. I have fought this very problem with my truck and found the bad seal along with a lifter that did not want to maintain the proper tension on the lifter. New valve seals and a new lifter fixed things with no negative effects. Granted, as soon as I noticed the oil pressure bobble, I happened to be near a parts store and immediately checked the oil level and found it really low. IN my case, the lifter noise had been there for a little bit, but the oil seal issue popped up almost overnight.
