Installed Raptor lights last week
armoredsaint
Ohio
Got it from F150led, wanted the 3 light but our grilles don't have the middle cutout so i got the four, it's not bad - but I would like to dim it down just a bit possibly. Looks better in person than pics because the camera gives that halo effect. I wired it to the fogs for control, I really wanted to wire it to the side marker lights but that was a lot more difficult to access.
SnodB
Dulles, VA
Really nice look. Could you share the part number or link on F150led. Was it complicated to wire into the fogs? Any pics of how they mount to grill or the wiring at fogs? If not, no worries but thought I would ask. Enjoy!!
RABAYL01
United States
Nicely done. So to turn these on during the day, do you still use the auto headlight function? I thought to get the fogs on during the day you turn on the parking lamps manually
armoredsaint
armoredsaint
Ohio
it was very easy about 2/10 on difficulty, the fogs are in the inner front wheel well and tap it into there, there's a youtube video but it's all F150's but basically the same install except the wiring is different especially if you have the 2022+ and LEDs
armoredsaint
armoredsaint
Ohio
it'll only turn on if i have the fogs on, the preferred method would be the side marker lights but access was difficult. the fog was simple to tap into and just button everything up with zip-ties.
SnodB
Dulles, VA
Thanks for the additional info and the link to F150leds - will definitely give it a a closer work. Great job on your install!
