No cruise control after bearing replacment
gural
Poland / Europe
Dear all
Few days ago a had a beraing replacment (it was noisy) It went that something was going out of it.
Car was driging normalny, no extra lamps on dash board
But 2 days ago I was going on a trip and I do not have cruise control
After engine start I can turn it on but after few second it disepaears
I putted a for scan and go a code C1A95:62
Can it be that the gay unplaged some wires and dod not plug them back??
ABS ESP 4x4 drive modes - all are working properly
I change it to moog bearing
w8ing for some tips
BestRegards
G
gural
Poland / Europe
i took code from for scan in polish:
Kod: C1A95 - Obwód czujnika prędkości koła
Dodatkowe symptomy usterki :)62):
- Błąd porównania sygnału
Status (-EC):
- DTC zmienił się w usterkę stałą - usterka sporadyczna w czasie wydania polecenia
- Kontrolka usterki włączona przy tym DTC
- Test nie został ukończony
Moduł: Układ przeciwdziałający blokowaniu hamulców (Antilock BrakingSystem).
You says it is installed wrong way (revers)
how can I chek it by my self??
Woodwolf
MI & ON
Status (-EC):
Make:FordCode:C1A95:62Definition:Wheel Speed Sensor: Signal Compare FailureCause:This DTC is set when the ABS module detects one wheel speed sensor mounted in the wrong direction.Failure Type:Signal Compare FailureThis sub type is used for failures where the control module compares two or more input parameters for plausibility.
DTC=Diagnostic Trouble Code
G
gural
Poland / Europe
thx for information
after coming back home i will go to mechanic that was changing the bearing to fix it
Justincrutledge
Pennsylvania
I am having the same issue, did you ever get this resolved? I am also having a shift sys fault when I put the truck in reverse
