Raining coolant
aeorn
aeorn
California
Thanks for the tip on the water pump. Coolant flooding stopped.
aeorn
aeorn
California
I found a new leak unfortunately. Much smaller. Can anyone tell me what this part? how big is this gasket job?
engineer1
Alabama
Be prepared when you remove the intake manifold that you may find more than a gasket issue. My '03 EB had the same leak, but I discovered the gasket is more of a formed O ring seal that sits in a channel molded into the plastic manifold. My manifold had cracked/broken so it no longer contained the seal. I cleaned up the damaged area very well, put some mold release on the old seal and put it back into the channel as a mold. I was then able to reinforce it with some steel (paper clip), and epoxied it with JB Weld. After it cured I installed a new seal, liberally added silicone rubber sealer, and bolted it together before the rubber set up. It seemed to have worked. Much less expensive than a new manifold. Good luck.
Hamfisted
Ft Lauderdale
You never replaced that crossover gasket ? Could be worse now. Because that joint on the intake manifold to crossover likes to de-laminate along the gasket sealing area if the gasket is not replaced early, and that requires a new intake manifold. Again, buy a pressure test kit and pressure test the system with the engine off. But don't delay that repair.
whtbronco
Winchester, VA
With the fluid present, I guess it's coolant, it very well may be a gasket, hose or the intake manifold leaking. Though if all I had was the audio I would say it's a vacuum leak.
aeorn
aeorn
California
Thanks for the tips. Went ahead and replaced the whole manifold yesterday. So much water in the valley and ignition coils. Gaskets were useless. It smoked a lot when I started because so much fluid drained into the cylinder when I pulled the spark plugs to dry them out. Running well today though. So far no leaks.
Btw, the new manifold is smaller and gives me a lot better access to the valley. I wonder if there's any performance difference.
