My 2019 has started making a rattle noise when under load very near 2k RPM. It immediately goes away if I let off the gas and also once past ~2200 RPM if I get heavy on the gas. It doesn't make it at 2k RPM in neutral or when brake torquing. It also doesn't seem to do it at 2k RPM if very lightly on the gas (little to no load).
I've checked the heat shields and all clamps appear tight and in tact. I put on the waste gate springs in a hope that may be the source but as I suspected that were not (or springs didn't fix)
