There are 3rd party replacements available, but they are only a few $$ less than the OEM versions, but the stationary ones willAre there any other stationary running board options either OEM or aftermarket that would replace the power running boards on a 2017 ford expedition LTD long box?
Thanks
what would be a ford OEM stationary replacement that could replace the power boards? Do you know a part #?There are 3rd party replacements available, but they are only a few $$ less than the OEM versions, but the stationary ones will
have different mounting points & placements than the power ones, which means they probably would require some drilling, and also plugging the old bolt holes to prevent water & dirt from getting in & rusting out that part of the frame...
lookie here:
www.fordpartsgiant.com
www.rockauto.com
www.tascaparts.com
www.partsgeek.com
Good luck
Sorry I don't know the specific part #'s, but surely you can search those sites & come up with something....if not, you could always call them to ask for advicewhat would be a ford OEM stationary replacement that could replace the power boards? Do you know a part #?
