The title says it all...
If you'd like to skip the background my main question is at the bottom of the post. Thanks.
A little background on the truck, it's an 06 XLT 5.4L 4x4 with advanctrac and I've owned it for 3-4 months now. I bought it with about 122k and now have about 127k with some issues. Also should mention that the truck came with some no-name all terrain tires that are pretty knobby (I'll get to that later).
Here what's been repaired/replaced/added:
New steering rack
Rear wheel bearings
Abs sensors
Spark plugs
Rear wiper linkage
Some fuses
Led interior lights
Clarion head unit (came with it)
When I purchased the truck I noticed on the test drive by myself without the PO that once it got to about 20-25 mph I stared to hear a harmonic hum the pulsated on turns and remained a constant tone on the straights ...I should mention that you still hear the hum through 80mph it just gets a bit quieter... Was somewhat clueless to what it could be but I figured hubs. (The PO said it was the "beefy" tires). But something that threw me towards it not being the wheel bearings was when I tested the 4WD. I found a school parking lot near the PO's house that happened to be grass so seemed like a perfect test spot for the 4x4. I first tried A4WD and noticed the when the wheel was slightly turned I heard a loud snap when I hit the accelerator... Same thing going straight. 4HI and 4LO produced the same response, when I accelerated I would hear a loud snap or clunk then the truck would go.
Thinking it was repairable I bought the truck and it passed inspection in RI. I took it to my dealer for an evaluation and they noticed the big problem areas for me and I had replaced what was necessary, i.e. Steering rack, rear hubs, transfer case fluid, oil change, abs sensor, spark plugs and a few more tiny things I did myself. But they never said anything about the 4WD system.
I have ignored it until the snow has now started to fall and I prefer to drive around in A4WD and feel safer that way. I have read around the forum and other forums a lot and have heard many many different things about what it could be. My thinking is maybe the CV shafts need to be replaced but I don't see grease coming out of them or any tears and also many the IWE solenoids on the front wheels but I am unsure and don't want to dump money where it doesn't need to be dumped. Reminder I did not have the front hubs replaced because the dealer said it was "not needed" and they were in good shape.
My main question is,
What could be making the constant hum noise while moving along the road and what could be making the the single loud snap noise when I accelerate hard in 4WD (sometimes experience some wheelspin)?Could the same thing be causing these noises and could it be the CVs?
Any information would be very helpful and greatly appreciated as I'm pressed for money and time because I'm going to back school and will only be able to work part time again.
Thank you in advance to anyone who can chime in with some help and I'll be happy to provide any info needed.
New steering rack
Rear wheel bearings
Abs sensors
Spark plugs
Rear wiper linkage
Some fuses
Led interior lights
